Zum Hauptinhalt wechseln
Kodak EasyShare M381 Back Panel Frame Replacement
Was du brauchst
  1. Kodak EasyShare M381 Back Panel Frame Replacement, Battery: Schritt 1, Bild 1 von 2 Kodak EasyShare M381 Back Panel Frame Replacement, Battery: Schritt 1, Bild 2 von 2
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Back Panel Frame Replacement: Schritt 2, Bild 1 von 1
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Back Panel Frame Replacement, Back Panel Frame: Schritt 3, Bild 1 von 3 Kodak EasyShare M381 Back Panel Frame Replacement, Back Panel Frame: Schritt 3, Bild 2 von 3 Kodak EasyShare M381 Back Panel Frame Replacement, Back Panel Frame: Schritt 3, Bild 3 von 3
    • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  4. Kodak EasyShare M381 Back Panel Frame Replacement: Schritt 4, Bild 1 von 2 Kodak EasyShare M381 Back Panel Frame Replacement: Schritt 4, Bild 2 von 2
    • Using both hands, carefully pull the frame apart from the camera.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 17
Insgesamt: 299
