Zum Hauptinhalt wechseln
Kodak Easyshare C183 Lens Assembly Replacement
Was du brauchst
  1. Kodak Easyshare C183 Lens Assembly Replacement, Lens: Schritt 1, Bild 1 von 3 Kodak Easyshare C183 Lens Assembly Replacement, Lens: Schritt 1, Bild 2 von 3 Kodak Easyshare C183 Lens Assembly Replacement, Lens: Schritt 1, Bild 3 von 3
    • Remove the batteries, memory card and wrist strap, if so equipped.
    • Remove the three Phillips screws on the bottom.
    • Remove the two Phillips screws on the right hand side.
  2. Kodak Easyshare C183 Lens Assembly Replacement: Schritt 2, Bild 1 von 3 Kodak Easyshare C183 Lens Assembly Replacement: Schritt 2, Bild 2 von 3 Kodak Easyshare C183 Lens Assembly Replacement: Schritt 2, Bild 3 von 3
    • Remove the two screws on the left hand side.
    • Nicely enough, all the screws are the same size. No need to keep them separated.
    • Start splitting the case from the battery holder. You can use an opening tool or just your fingernails.
  3. Kodak Easyshare C183 Lens Assembly Replacement: Schritt 3, Bild 1 von 3 Kodak Easyshare C183 Lens Assembly Replacement: Schritt 3, Bild 2 von 3 Kodak Easyshare C183 Lens Assembly Replacement: Schritt 3, Bild 3 von 3
    • The camera's front half will come off first.
    • Remove the one screw on the top left of the camera. It this holds the back case on to the midframe.
    • Remove the back case.
  4. Kodak Easyshare C183 Lens Assembly Replacement: Schritt 4, Bild 1 von 3 Kodak Easyshare C183 Lens Assembly Replacement: Schritt 4, Bild 2 von 3 Kodak Easyshare C183 Lens Assembly Replacement: Schritt 4, Bild 3 von 3
    • Gently move the LCD out of the holder. DO NOT TRY TO REMOVE THE LCD. Just fold it over.
    • Remove the one screw on the top corner of the holder.
    • Remove the ribbon cable from its connector. It is just pushed in. there are not clips to move. Gently pull it straight down.
    • Remove the solder that connects the LCD holder to the top logic board.
  5. Kodak Easyshare C183 Lens Assembly Replacement: Schritt 5, Bild 1 von 3 Kodak Easyshare C183 Lens Assembly Replacement: Schritt 5, Bild 2 von 3 Kodak Easyshare C183 Lens Assembly Replacement: Schritt 5, Bild 3 von 3
    • The LCD holding board and the switches are removed as one unit.
    • Open the clip on the LCD ribbon cable connector. Use your fingernails to gently pull it toward the top of the camera.
    • Remove the LCD.
  6. Kodak Easyshare C183 Lens Assembly Replacement: Schritt 6, Bild 1 von 3 Kodak Easyshare C183 Lens Assembly Replacement: Schritt 6, Bild 2 von 3 Kodak Easyshare C183 Lens Assembly Replacement: Schritt 6, Bild 3 von 3
    • Open the connectors for the CCD and the lens. Both use a clip that hold the cable is places. Move those gently into the opposite direction of the cables. this will free the cable.
    • Remove the two screws that hold the lens in place.
    • With the screws and the cables removed, use your fingers and push the lens upward and angled out of the midframe.
  7. Kodak Easyshare C183 Lens Assembly Replacement: Schritt 7, Bild 1 von 1
    • This is what your final result should look like. the lens is now free from the midframe and a new lens can be easily installed.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
oldturkey03
782.402 Reputation
119 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
544 Anleitungen geschrieben
2 Kommentare
ممنون از اطلاعات تان
hamid kaker - Antwort
خواهش میکنم. امیدوارم کمک کرده باشد.
oldturkey03 -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 1,842
