Was du brauchst
Turn off the camera by turning the selector dial to “off.” This is located on top of the camera body.
Locate memory compartment on the side of the camera body and slide open by applying pressure in the direction of the arrow. Door will spring open.
Insert memory card (SD card) with the gold terminals facing downward. Gently press down until into you feel it lock into place. Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it out. Close memory compartment door.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
