Zum Hauptinhalt wechseln
Kodak Easyshare V1003 LCD Display Replacement
Was du brauchst
  1. Kodak Easyshare V1003  LCD Display Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera.
  2. Kodak Easyshare V1003  LCD Display Replacement: Schritt 2, Bild 1 von 1
    • Position camera with the bottom facing up.
  3. Kodak Easyshare V1003  LCD Display Replacement: Schritt 3, Bild 1 von 1
    • With your finger, slide the battery cover in the direction of the open arrow.
  4. Kodak Easyshare V1003  LCD Display Replacement: Schritt 4, Bild 1 von 1
    • Lift the battery cover up gently.
  5. Kodak Easyshare V1003  LCD Display Replacement: Schritt 5, Bild 1 von 2 Kodak Easyshare V1003  LCD Display Replacement: Schritt 5, Bild 2 von 2
    • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
  6. Kodak Easyshare V1003  LCD Display Replacement, Buttons: Schritt 6, Bild 1 von 3 Kodak Easyshare V1003  LCD Display Replacement, Buttons: Schritt 6, Bild 2 von 3 Kodak Easyshare V1003  LCD Display Replacement, Buttons: Schritt 6, Bild 3 von 3
    • Use a J00 screwdriver to remove the five exterior screws.
  7. Kodak Easyshare V1003  LCD Display Replacement: Schritt 7, Bild 1 von 3 Kodak Easyshare V1003  LCD Display Replacement: Schritt 7, Bild 2 von 3 Kodak Easyshare V1003  LCD Display Replacement: Schritt 7, Bild 3 von 3
    • Use a plastic opening tool to pry off the back casing.
  8. Kodak Easyshare V1003  LCD Display Replacement: Schritt 8, Bild 1 von 3 Kodak Easyshare V1003  LCD Display Replacement: Schritt 8, Bild 2 von 3 Kodak Easyshare V1003  LCD Display Replacement: Schritt 8, Bild 3 von 3
    • Completely remove the back casing from the device.
    • Using a plastic tool to remove the bottom.
  9. Kodak Easyshare V1003  LCD Display Replacement, LCD Display: Schritt 9, Bild 1 von 1
    • Remove the LCD display by unplugging the connector.
  10. Kodak Easyshare V1003  LCD Display Replacement: Schritt 10, Bild 1 von 1
    • Take apart the LCD display from the back case.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Vanessa Soares
222 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S9-G4, Martin Spring 2017 Mitglied von UMass Dartmouth, Team S9-G4, Martin Spring 2017
UMASSD-MARTIN-S17S9G4
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Hi Vanessa
Where in South Africa (Gauteng) can I buy a lcd display replacement screen for this Kodak easyshare v1003 camera?
Wickus: +27725966377/ vwickus@ymail.com
vwickus - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 27
Insgesamt: 716
