Einleitung
This guide provides step-by-step instructions for removing and replacing the battery. There are two tools required and no safety precautions needed.
Was du brauchst
Turn off camera by firmly pressing the power button that is located on the top of the camera.
Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
Completely remove the back casing from the device.
Using a plastic tool to remove the bottom.
