Zum Hauptinhalt wechseln
Kodak Easyshare V1003 Lens Replacement
Was du brauchst
  1. Kodak Easyshare V1003 Lens  Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera.
  2. Kodak Easyshare V1003 Lens  Replacement: Schritt 2, Bild 1 von 1
    • Position camera with the bottom facing up.
  3. Kodak Easyshare V1003 Lens  Replacement: Schritt 3, Bild 1 von 1
    • With your finger, slide the battery cover in the direction of the open arrow.
  4. Kodak Easyshare V1003 Lens  Replacement: Schritt 4, Bild 1 von 1
    • Lift the battery cover up gently.
  5. Kodak Easyshare V1003 Lens  Replacement: Schritt 5, Bild 1 von 2 Kodak Easyshare V1003 Lens  Replacement: Schritt 5, Bild 2 von 2
    • Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
  6. Kodak Easyshare V1003 Lens  Replacement, Lens: Schritt 6, Bild 1 von 2 Kodak Easyshare V1003 Lens  Replacement, Lens: Schritt 6, Bild 2 von 2
    • Use a J00 screwdriver to remove the five exterior screws.
  7. Kodak Easyshare V1003 Lens  Replacement: Schritt 7, Bild 1 von 1
    • Pull the outer case off using the plastic opening tool.
  8. Kodak Easyshare V1003 Lens  Replacement: Schritt 8, Bild 1 von 2 Kodak Easyshare V1003 Lens  Replacement: Schritt 8, Bild 2 von 2
    • Remove the LCD display by unplugging the connector
    • Take apart the LCD display from the back case
  9. Kodak Easyshare V1003 Lens  Replacement: Schritt 9, Bild 1 von 2 Kodak Easyshare V1003 Lens  Replacement: Schritt 9, Bild 2 von 2
    • Peel off the yellow film.
    • Peel off the black tape holding the wires.
  10. Kodak Easyshare V1003 Lens  Replacement: Schritt 10, Bild 1 von 1
    • Unplug the connector by lifting the little lock holding it in place.
  11. Kodak Easyshare V1003 Lens  Replacement: Schritt 11, Bild 1 von 2 Kodak Easyshare V1003 Lens  Replacement: Schritt 11, Bild 2 von 2
    • Use a J00 screwdriver to remove two screws located on the far right, near to the main button.
  12. Kodak Easyshare V1003 Lens  Replacement: Schritt 12, Bild 1 von 3 Kodak Easyshare V1003 Lens  Replacement: Schritt 12, Bild 2 von 3 Kodak Easyshare V1003 Lens  Replacement: Schritt 12, Bild 3 von 3
    • Use a J00 screwdriver to remove 6 screws located at the center of the back panel.
    • Gently pull out the lens using you finger tips or pincers.
Abschluss
Sarah Berry
301 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S9-G4, Martin Spring 2017 Mitglied von UMass Dartmouth, Team S9-G4, Martin Spring 2017
UMASSD-MARTIN-S17S9G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 319
