Einleitung
This guide provides step-by-step instructions for removing and replacing the camera lens. There are two tools required and no safety precautions needed.
Was du brauchst
Turn off camera by firmly pressing the power button that is located on the top of the camera.
Gently push the battery down until a click is heard. Battery should release and be lifted out of slot.
Remove the LCD display by unplugging the connector
Take apart the LCD display from the back case
Use a J00 screwdriver to remove two screws located on the far right, near to the main button.
Use a J00 screwdriver to remove 6 screws located at the center of the back panel.
Gently pull out the lens using you finger tips or pincers.
