Zum Hauptinhalt wechseln
Kodak Easyshare Z981 Back Cover Replacement
Was du brauchst
  1. Kodak Easyshare Z981 Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 3 Kodak Easyshare Z981 Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 3 Kodak Easyshare Z981 Back Cover Replacement, Back Cover: Schritt 1, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Phillips #00 Screwdriver
    $5.49
    • Remove screws using a 00 Phillips-Head screwdriver:
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) on the bottom of the camera
    • Four (4) inside the battery cover
  2. Kodak Easyshare Z981 Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Start from a corner and gently remove the bottom cover of the camera.
    • The cover will easily lift off without much pressure necessary.
  3. Kodak Easyshare Z981 Back Cover Replacement: Schritt 3, Bild 1 von 2 Kodak Easyshare Z981 Back Cover Replacement: Schritt 3, Bild 2 von 2
    $5.49
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  4. Kodak Easyshare Z981 Back Cover Replacement: Schritt 4, Bild 1 von 2 Kodak Easyshare Z981 Back Cover Replacement: Schritt 4, Bild 2 von 2
    • Use a Plastic Opening Tool to remove the back of the camera and pull gently on the cover to remove the cover
    • Start from one corner and apply light pressure with the tool.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Sam Houston State, Team 13-6, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 13-6, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S13G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 930
