Was du brauchst
Open the battery cover and remove the AA batteries from the camera if any are inserted.
Remove screws using a 00 Phillips-Head screwdriver:
Eight (8) 3mm screws on the lower portion of the camera
Four (4) on the bottom of the camera
Four (4) on the inside of the battery cover
Four (4) 6mm screws on the sides of the camera (two on each side)
Remove the four (4) 3mm screws attaching the LCD screen to the circuit board.
Use Tweezers to carefully detach the ribbon cable
Remove four (4) 3mm screws from the circuit board underneath the button set.
Gently move the circuit board aside.
Gently move aside the metal sheet.
Use Tweezers to carefully remove the flash button.
