Zum Hauptinhalt wechseln
Kodak Easyshare Z981 LCD Screen Replacement
Was du brauchst
  1. Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 2 Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 2 von 2
    • Open the battery cover and remove batteries from the camera if any are inserted.
  2. Kodak Easyshare Z981 LCD Screen Replacement: Schritt 2, Bild 1 von 2 Kodak Easyshare Z981 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Phillips #00 Screwdriver
    $5.49
    • Use a 00 Phillips-Head screwdriver to remove screws:
    • Remove the 3 mm screws from the camera
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
  3. Kodak Easyshare Z981 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Start from a corner and gently remove the cover.
    • The cover will easily lift off, so not much pressure is required.
    • Make sure to gently remove the bottom cover in order to avoid breaking the plastic.
  4. Kodak Easyshare Z981 LCD Screen Replacement: Schritt 4, Bild 1 von 2 Kodak Easyshare Z981 LCD Screen Replacement: Schritt 4, Bild 2 von 2
    $5.49
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  5. Kodak Easyshare Z981 LCD Screen Replacement: Schritt 5, Bild 1 von 2 Kodak Easyshare Z981 LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Insert the Plastic Opening Tool in to the crevices of back cover and gently apply pressure
    • Be gentle while removing the cover, to avoid cracking the case
  6. Kodak Easyshare Z981 LCD Screen Replacement: Schritt 6, Bild 1 von 2 Kodak Easyshare Z981 LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Once the back cover is removed locate the four 3mm screws holding the screen and the metal brace to the circuit board
  7. Kodak Easyshare Z981 LCD Screen Replacement: Schritt 7, Bild 1 von 3 Kodak Easyshare Z981 LCD Screen Replacement: Schritt 7, Bild 2 von 3 Kodak Easyshare Z981 LCD Screen Replacement: Schritt 7, Bild 3 von 3
    • Gently lift up the metal brace and use a pair of tweezers to disconnect the ribbon cable connector.
    • Remove the screen brace from the circuit board.
    • Use extreme caution when removing the LCD brace; pulling the brace may tear the cable.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Sam Houston State, Team 13-6, Blackburne Winter 2015 Mitglied von Sam Houston State, Team 13-6, Blackburne Winter 2015
SHSU-BLACKBURNE-W15S13G6
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 881
