Einleitung
The rubber grip, located on the front of your Kodak PixPro AZ251, gives you a better grip of the camera. This guide will instruct you on how to remove the rubber pad.
Was du brauchst
Insert the plastic opening tool underneath the rubber on the bottom corner.
Slide the plastic opening tool along the perimeter of the rubber grip to unbind the glue.
Fast fertig!
Abschluss
