Zum Hauptinhalt wechseln
Kodak S100 EF Flash Capacitor Replacement
Was du brauchst
  1. Kodak S100 EF Flash Capacitor Replacement, Back Cover: Schritt 1, Bild 1 von 2 Kodak S100 EF Flash Capacitor Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
  2. Kodak S100 EF Flash Capacitor Replacement: Schritt 2, Bild 1 von 1
    • Turn camera so the bottom is facing up and the front is facing away.
    • Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
    • Back cover is now unscrewed an can be removed.
  3. Kodak S100 EF Flash Capacitor Replacement: Schritt 3, Bild 1 von 1
    • Have the back of the camera facing up.
    • Unscrew the 6.2mm Phillips screw next to the viewfinder.
    • The back cover is now unscrewed. Lift up and pull the cover off evenly.
  4. Kodak S100 EF Flash Capacitor Replacement, Flash Capacitor: Schritt 4, Bild 1 von 1
    • The capacitor is located at the bottom center of the camera.
  5. Kodak S100 EF Flash Capacitor Replacement: Schritt 5, Bild 1 von 1
Abschluss
Michelle
131 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 25-28, Garner Spring 2011 Mitglied von Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 2,572
