Einleitung
To start, the Front Cover Teardown guide must be used. Later, soldering guides will be used.
Was du brauchst
Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
Unscrew the 6.2mm Phillips screw on the top right.
The front cover is now unscrewed and should be lifted evenly and removed.
Once the front cover is off, desolder the connections at both ends of the flash.
If unfamiliar with soldering, refer to the guide Wie man Lötverbindungen herstellt und entlötet
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
