Einleitung
This will guide through the process of rolling up to remove the film as well as replacing it with a new roll. The Kodak S100 EF uses 35mm film.
Werkzeuge
Kein Werkzeug erforderlich.
Ersatzteile
  1. Lift up the lever from the center of the film roller.
    • Lift up the lever from the center of the film roller.
    • Turn it clockwise to roll up the film until you feel the roller release, indicating all the film has been rolled up.
  2. On the far left side on the back of the camera there is a switch that says "open."
    • On the far left side on the back of the camera there is a switch that says "open."
    • Slide the button up to the top where it says "open."
    • This should pop open the door, revealing the rolled up film inside.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. To take out the old film and insert the new, you must lift up on the film roller.
    • To take out the old film and insert the new, you must lift up on the film roller.
    • Pull up on the lever to pop the roller up which will release the film.
    • After old roll is removed, slide in the new roll and push the roller back down to secure the film.
  5. To prepare the film for use, grab the tail of the film and pull it out slightly.
    • To prepare the film for use, grab the tail of the film and pull it out slightly.
    • Drag it out to the rotating column on the right side.
    • At the base of the column there are hooks to attach to the holes at the bottom of the film.
    • Slip one of the hooks into the first hole of your film to attach.
  6. After film is secured, close the camera door.
    • After film is secured, close the camera door.
    • Make sure the lever is put back in place on the film roller.
    • Use the scroll wheel to advance the film until it is ready to take pictures.
Abschluss
Once the film is in place-to reassemble the camera-close the camera door and make sure the scroll wheel is pushed back down.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Michelle
86 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 25-28, Garner Spring 2011 Mitglied von Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Mitglieder
6 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 48
Insgesamt: 4,035
