Zum Hauptinhalt wechseln
Kodak S100 EF Front Cover Replacement
Was du brauchst
  1. Kodak S100 EF Front Cover Replacement, Front Cover: Schritt 1, Bild 1 von 1
    • Have the camera facing upwards and the flash closest to you.
    • Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
  2. Kodak S100 EF Front Cover Replacement: Schritt 2, Bild 1 von 1
    • Flip the camera over to the other side-with flash farthest from you.
    • Unscrew top two 6.2mm Phillips screws on this side.
  3. Kodak S100 EF Front Cover Replacement: Schritt 3, Bild 1 von 1
    • Turn the camera so the bottom is facing up with the front-facing away.
    • Unscrew the 6.2mm Phillips screw on the top right.
    • The front cover is now unscrewed and should be lifted evenly and removed.
Abschluss
Michelle
107 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 25-28, Garner Spring 2011 Mitglied von Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,993
