Einleitung
First, complete the teardown guide in order to access the lens.
Was du brauchst
Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
Unscrew the 6.2mm Phillips screw on the top right.
The front cover is now unscrewed and should be lifted evenly and removed.
Remove the two 6.2mm Phillips screws on either side of the lens securing the metal plate.
Lift metal panel and insert screwdriver through holes in panel to reach screws underneath. Remove the two 6.2mm Phillips screws.
Unscrew two 6.2mm Phillips screws on the black plate next to the lens.
At this point, all screws are removed and lens can should be carefully lifted and removed, including both plates and the plastic ring around the lens.
