Einleitung
If the shutter on your Kodak Signet 35 isn't working properly, then the shutter spring may need to be cleaned or replaced. This guide will show you how. Please make sure you have all the necessary tools, as well as a clean and stable surface on which to work, before you start these steps.
Was du brauchst
While the camera is lying on its back, unscrew the front lens assembly and remove the lens and the faceplate. Then lift off the speed setting.
Remove the stopper by lifting it upwards with the tweezers.
Using tweezers, unhitch the spring from the base and remove it by lifting upwards.
2 Kommentare
What does “front lens assembly” look like? what parts do I have to unscrew?
