Zum Hauptinhalt wechseln
Einleitung
The “Free-Stand” button enables the stroller to fold into a freestanding, compact position. Sometimes the button can get stuck and requires simple internal repair. This guide will walk you through that process.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case. You may want to flip the stroller over to access the screws.
    • Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
    • You may want to flip the stroller over to access the screws.
  2. Remove the back cover of the case by lifting it straight up.
    • Remove the back cover of the case by lifting it straight up.
  3. The spring may pop out while removing the "Free Stand" button, so lift the button slowly to avoid losing the spring.
    • The spring may pop out while removing the "Free Stand" button, so lift the button slowly to avoid losing the spring.
    • To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
  4. If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
    • If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
Abschluss
Cal Poly, Team 11-1, Forte Fall 2015 Mitglied von Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
4 Mitglieder
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 14
Insgesamt: 779
