Zum Hauptinhalt wechseln
Kolcraft Cloud Plus "Free-Stand" Button Replacement
Was du brauchst
  1. Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: Schritt 1, Bild 1 von 2 Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: Schritt 1, Bild 2 von 2
    • Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
    • You may want to flip the stroller over to access the screws.
  2. Kolcraft Cloud Plus "Free-Stand" Button Replacement: Schritt 2, Bild 1 von 1
    • Remove the back cover of the case by lifting it straight up.
  3. Kolcraft Cloud Plus "Free-Stand" Button Replacement: Schritt 3, Bild 1 von 1
    • The spring may pop out while removing the "Free Stand" button, so lift the button slowly to avoid losing the spring.
    • To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
  4. Kolcraft Cloud Plus "Free-Stand" Button Replacement: Schritt 4, Bild 1 von 1
    • If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
Abschluss
Cal Poly, Team 11-1, Forte Fall 2015 Mitglied von Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 28
Insgesamt: 1,273
