Zum Hauptinhalt wechseln
Einleitung
The wheels are vital to the stroller's function. Damaged or loose wheels can be frustrating, but wheel replacement is quick and painless.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Applying too much force to the spudger can cause the spudger to bend or the hubcap to break. To avoid this, try prying the hubcap from a different angle or positioning your spudger at a different points around the hubcap. Use the spaded side of the metal spudger to pry off the small black hubcap on the     outside of the rear wheel.
    • Applying too much force to the spudger can cause the spudger to bend or the hubcap to break. To avoid this, try prying the hubcap from a different angle or positioning your spudger at a different points around the hubcap.
    • Use the spaded side of the metal spudger to pry off the small black hubcap on the outside of the rear wheel.
  2. Pull on the looped end of the cotter pin to remove it. Pull on the looped end of the cotter pin to remove it.
    • Pull on the looped end of the cotter pin to remove it.
  3. Remove the metal washer by sliding it off the axle. Remove the metal washer by sliding it off the axle.
    • Remove the metal washer by sliding it off the axle.
  4. Slide the wheel off of the axle.
    • Slide the wheel off of the axle.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Cal Poly, Team 11-1, Forte Fall 2015 Mitglied von Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
4 Mitglieder
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 11
Letzten 30 Tage: 41
Insgesamt: 2,474
