Zum Hauptinhalt wechseln
Konica Minolta DiMAGE Z3 Battery Replacement
  1. Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: Schritt 1, Bild 1 von 2 Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: Schritt 1, Bild 2 von 2
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Konica Minolta DiMAGE Z3 Battery Replacement, Insert the batteries: Schritt 2, Bild 1 von 1
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
Abschluss
Hieu Ngo
431 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S7-G4, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S7-G4, Julie Spring 2017
UMASSD-JULIE-S17S7G4
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
The camera was stored with batteries inside. When opened recently, one had leaked. Now the camera will not start. Any suggestions? I tried to clean the battery compartment.. it is a bit corroded looking. Can this be repaired?
Maxine Bochnia - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 1,006
