Zum Hauptinhalt wechseln
Konica Minolta DiMAGE Z3 LCD Screen Replacement
Was du brauchst
  1. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: Schritt 1, Bild 1 von 2 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: Schritt 1, Bild 2 von 2
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
    Frag FixBot
  2. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Insert the batteries: Schritt 2, Bild 1 von 1
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
    Frag FixBot
  3. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: Schritt 3, Bild 1 von 2 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: Schritt 3, Bild 2 von 2
    • Use a screwdriver to remove the four viewfinder cover screws.
    Frag FixBot
  4. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove viewfinder screws: Schritt 4, Bild 1 von 1
    • Remove the 2 small screws under the viewfinder.
    Frag FixBot
  5. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the screen cover: Schritt 5, Bild 1 von 1
    • Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
    • Do not apply pressure to the surface of the LCD screen or it may be permanently damaged. If fingerprints are on the LCD monitor, gently wipe with a soft, clean, dry cloth.
    Frag FixBot
  6. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screws from the bottom panel: Schritt 6, Bild 1 von 1
    • Remove 6 screws on the bottom panel.
    Frag FixBot
  7. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screw from battery chamber: Schritt 7, Bild 1 von 1
    • Remove 1 screw on the outer side of the battery chamber.
    • This will be under the rubber grip.
    Frag FixBot
  8. Konica Minolta DiMAGE Z3 LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Remove 1 screw inside the battery chamber.
    Frag FixBot
  9. Konica Minolta DiMAGE Z3 LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Pull the wrist strap away from the front of the camera to remove it.
    • Then carefully pull the back casing apart from the camera.
    Frag FixBot
  10. Konica Minolta DiMAGE Z3 LCD Screen Replacement: Schritt 10, Bild 1 von 1
    • Remove the 3 screws that attach the LCD screen to the circuit board.
    Frag FixBot
  11. Konica Minolta DiMAGE Z3 LCD Screen Replacement: Schritt 11, Bild 1 von 1
    • Gently remove the LCD screen from the circuit board.
    • There will be a ribbon cable and some wires attached to the LCD screen.
    Frag FixBot
  12. Konica Minolta DiMAGE Z3 LCD Screen Replacement: Schritt 12, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
    • Peel back tape on LCD screen to reveal where the wires are attached. Use tweezers to detach the wires from the LCD screen.
    Frag FixBot
Abschluss
UMass Dartmouth, Team S7-G4, Julie Spring 2017 Mitglied von UMass Dartmouth, Team S7-G4, Julie Spring 2017
UMASSD-JULIE-S17S7G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 56
Insgesamt: 1,158
