Einleitung
This guide will show you how to replace the barrel shield spring on the Koosh Vortex Tornado.
Was du brauchst
Remove the fourteen 15 mm Phillips #1 screws on the side of the body.
Pull the halves of the toy gun apart to show the inside. Set the left half aside (all of the inside components are on the right half).
Using a spudger, unhook the barrel shield's spring from the right half of the toy gun. One side should still be connected to the shield barrel shield.
Eine weitere Person hat diese Anleitung absolviert.
