Zum Hauptinhalt wechseln
Koss Porta Pro Speaker Holder Replacement
Was du brauchst
  1. Koss Porta Pro Speaker Holder Replacement, Remove cushion: Schritt 1, Bild 1 von 3 Koss Porta Pro Speaker Holder Replacement, Remove cushion: Schritt 1, Bild 2 von 3 Koss Porta Pro Speaker Holder Replacement, Remove cushion: Schritt 1, Bild 3 von 3
    • Remove cushion using knife.
  2. Koss Porta Pro Speaker Holder Replacement, Remove comfortZone label: Schritt 2, Bild 1 von 2 Koss Porta Pro Speaker Holder Replacement, Remove comfortZone label: Schritt 2, Bild 2 von 2
    • Remove label using flat screwdriver.
  3. Koss Porta Pro Speaker Holder Replacement, Remove clip: Schritt 3, Bild 1 von 3 Koss Porta Pro Speaker Holder Replacement, Remove clip: Schritt 3, Bild 2 von 3 Koss Porta Pro Speaker Holder Replacement, Remove clip: Schritt 3, Bild 3 von 3
    • Use screwdriver to start bending edges of clip.
    • Continue bending with pliers or cutters.
    • Push clip with screwdriver and pull with cutters from another side.
    • This step can take up to 15 minutes, so keep calm and continue bending.
  4. Koss Porta Pro Speaker Holder Replacement, Remove hoop holder: Schritt 4, Bild 1 von 3 Koss Porta Pro Speaker Holder Replacement, Remove hoop holder: Schritt 4, Bild 2 von 3 Koss Porta Pro Speaker Holder Replacement, Remove hoop holder: Schritt 4, Bild 3 von 3
    • Press tenon using screwdriver to remove shield.
    • Remove hoop from hoop holder.
  5. Koss Porta Pro Speaker Holder Replacement, Assemble hoop holder: Schritt 5, Bild 1 von 3 Koss Porta Pro Speaker Holder Replacement, Assemble hoop holder: Schritt 5, Bild 2 von 3 Koss Porta Pro Speaker Holder Replacement, Assemble hoop holder: Schritt 5, Bild 3 von 3
    • Place hoop in hoop holer.
    • Close hoop holder with shield.
    • Insert M2.5x8 screw into hole and tighten the nut.
  6. Koss Porta Pro Speaker Holder Replacement, Stick cushion and label: Schritt 6, Bild 1 von 3 Koss Porta Pro Speaker Holder Replacement, Stick cushion and label: Schritt 6, Bild 2 von 3 Koss Porta Pro Speaker Holder Replacement, Stick cushion and label: Schritt 6, Bild 3 von 3
    • Stick comfortZone label over the screw. Use double-sided foam tape if head of screw is too high.
    • Stick cushion. Use additional double-sided tape if cushion has bad holding.
Abschluss
Left and right sides are the same so you can use this guide for both.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 49
Insgesamt: 1,896
