1. Make sure the device is unplugged before continuing.
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Remove the single black Phillips size 0 10mm length screw on the back of the machine.
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the bottom cover from the machine and slide it down the power cord.
    • Remove the bottom cover from the machine and slide it down the power cord.
  5. Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
    • Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
  6. Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
    • Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
Abschluss
Wyatt Hall
812 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 6-25, Maness Fall 2014 Mitglied von Cal Poly, Team 6-25, Maness Fall 2014
CPSU-MANESS-F14S6G25
4 Mitglieder
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
susangellert - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 1,550
