Zum Hauptinhalt wechseln
Kurio 10S Back Cover Replacement
Was du brauchst
  1. Kurio 10S Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn the device over and place it with the screen down on a flat surface that is clean so the screen does not get scratched.
  2. Kurio 10S Back Cover Replacement: Schritt 2, Bild 1 von 2 Kurio 10S Back Cover Replacement: Schritt 2, Bild 2 von 2
    • Locate the four screws, two on each side.
    • Using the philips head screwdriver, carefully remove each screw and keep them together in a safe location.
  3. Kurio 10S Back Cover Replacement: Schritt 3, Bild 1 von 1
    • Once all screws are removed, use a spudger to get under a corner and unclip the hooks.
    • Once the spudger is under the cover, slide it all the way around the device, pushing lightly into the device making sure it stays under the cover until all the clips are removed.
    • The back cover is difficult to remove, so do not be afraid of using some force once all of the clips have been removed.
  4. Kurio 10S Back Cover Replacement: Schritt 4, Bild 1 von 1
    • The back cover should then be able to easily be removed from the device and you should see the battery and other internal components.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Timothy Kramer
325 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 1-6, Shastany Spring 2015 Mitglied von UMass Dartmouth, Team 1-6, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G6
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 616
