Zum Hauptinhalt wechseln
Kurio Touch 4S Front & Rear Facing Cameras Replacement
Was du brauchst
  1. Kurio Touch 4S Front & Rear Facing Cameras Replacement, Front & Rear Facing Cameras: Schritt 1, Bild 1 von 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 2, Bild 1 von 3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 2, Bild 2 von 3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 2, Bild 3 von 3
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 3, Bild 1 von 3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 3, Bild 2 von 3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 3, Bild 3 von 3
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
  4. Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 4, Bild 1 von 1
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you miss them up.
  5. Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 5, Bild 1 von 1
    • Remove the battery because it blocks the plastic shield that covers the camera.
    • Do not remove the wires that are attached to the battery and the motherboard.
  6. Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 6, Bild 1 von 1
    • Remove the plastic cover that is covering the camera area using tweezers.
  7. Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 7, Bild 1 von 2 Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 7, Bild 2 von 2
    • Separate the two halves of your Kurio Touch 4S.
    • Gently use a brush to remove any dirt or finger prints around the area.
    • Use the Tweezers to detach the front and back camera from its place.
  8. Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 8, Bild 1 von 2 Kurio Touch 4S Front & Rear Facing Cameras Replacement: Schritt 8, Bild 2 von 2
    • Remove the copper wires by using the Tweezers to replace your new camera.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 6-5, Brown Winter 2015 Mitglied von USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 242
