Zum Hauptinhalt wechseln
Kurio Touch 4S Power Button Replacement
Was du brauchst
  1. Kurio Touch 4S Power Button Replacement, Power Button: Schritt 1, Bild 1 von 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Power Button Replacement: Schritt 2, Bild 1 von 3 Kurio Touch 4S Power Button Replacement: Schritt 2, Bild 2 von 3 Kurio Touch 4S Power Button Replacement: Schritt 2, Bild 3 von 3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Power Button Replacement: Schritt 3, Bild 1 von 2 Kurio Touch 4S Power Button Replacement: Schritt 3, Bild 2 von 2
    • To remove the battery, make sure the four 5mm Phillips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Power Button Replacement: Schritt 4, Bild 1 von 1
    • After you remove your four 5mm Philips screws use your plastic opening tool to help you open the plastic cover of your device.
  5. Kurio Touch 4S Power Button Replacement: Schritt 5, Bild 1 von 1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  6. Kurio Touch 4S Power Button Replacement: Schritt 6, Bild 1 von 1
    • Gently remove the plastic cover that is covering the camera.
  7. Kurio Touch 4S Power Button Replacement: Schritt 7, Bild 1 von 1
    • Use Phillips # 1 screw to open the four 5mm Philips screws on the motherboard.
    • Open the screws gently and do not apply too much force as you could damage the motherboard.
  8. Kurio Touch 4S Power Button Replacement: Schritt 8, Bild 1 von 1
    • Use the plastic opener to remove the battery.
  9. Kurio Touch 4S Power Button Replacement: Schritt 9, Bild 1 von 1
    • Use tweezers to remove the black tape that is attached to the motherboard.
  10. Kurio Touch 4S Power Button Replacement: Schritt 10, Bild 1 von 2 Kurio Touch 4S Power Button Replacement: Schritt 10, Bild 2 von 2
    • Detach all the wire that are connected to the motherboard.
    • Detach the camera module and other components that are attached to the motherboard.
  11. Kurio Touch 4S Power Button Replacement: Schritt 11, Bild 1 von 1
    • Remove the motherboard with the help of plastic opener.
    • Detach the power plug before you remove the motherboard.
  12. Kurio Touch 4S Power Button Replacement: Schritt 12, Bild 1 von 1
    • Use tweezers to hold the power button and gently lift it up.
    • Replace the old power button with the new one.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Moin Khan
234 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 6-5, Brown Winter 2015 Mitglied von USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 464
