Zum Hauptinhalt wechseln
Kurio Xtreme Battery Replacement
Was du brauchst
  1. Kurio Xtreme Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Battery Replacement: Schritt 2, Bild 1 von 2 Kurio Xtreme Battery Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Battery Replacement: Schritt 3, Bild 1 von 3 Kurio Xtreme Battery Replacement: Schritt 3, Bild 2 von 3 Kurio Xtreme Battery Replacement: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Battery Replacement, Battery: Schritt 4, Bild 1 von 2 Kurio Xtreme Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Disconnect the black and red wires from the motherboard by soldering the ends that are connected to the motherboard.
    • The soldering iron gets very hot and may injure you if exposed to your skin.
  5. Kurio Xtreme Battery Replacement: Schritt 5, Bild 1 von 2 Kurio Xtreme Battery Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    • Slide iFixit's Plastic Card tool or a credit card under the battery to remove the glue that is holding it in place.
    • Be patient and gentle. The glue is strong and may take up to 30 seconds to remove.
    • Carefully lift the battery out of the device.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Mallory Myers
1.190 Reputation
7 Anleitungen geschrieben
Baylor, Team 6-10, Williams Fall 2015 Mitglied von Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Mitglieder
14 Anleitungen geschrieben
2 Kommentare zur Anleitung
j ai changé de batterie mais la batterie ne charge pas. est ce que c ets parce qu un des deux fils serait mal soudé?
j-p1955 - Antwort
Does it have a certain battery or can a different battery fit?
Nikki Gilliard - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 4,131
