Zum Hauptinhalt wechseln
Kurio Xtreme Camera Replacement
Was du brauchst
  1. Kurio Xtreme Camera Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Camera Replacement: Schritt 2, Bild 1 von 2 Kurio Xtreme Camera Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Camera Replacement: Schritt 3, Bild 1 von 3 Kurio Xtreme Camera Replacement: Schritt 3, Bild 2 von 3 Kurio Xtreme Camera Replacement: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Camera Replacement, Camera: Schritt 4, Bild 1 von 1
    • Remove the flat-topped connector that connects the cameras to the motherboard by using the plastic opening tool to pry up on each side.
  5. Kurio Xtreme Camera Replacement: Schritt 5, Bild 1 von 3 Kurio Xtreme Camera Replacement: Schritt 5, Bild 2 von 3 Kurio Xtreme Camera Replacement: Schritt 5, Bild 3 von 3
    • Remove the smaller, front facing camera by lifting up on the attached ribbon cable.
    • Remove the larger, rear facing camera by lifting up on the attached ribbon cable.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Mallory Myers
1.190 Reputation
7 Anleitungen geschrieben
Baylor, Team 6-10, Williams Fall 2015 Mitglied von Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 254
