Zum Hauptinhalt wechseln
Kurio Xtreme Touch Screen Replacement
Was du brauchst
  1. Kurio Xtreme Touch Screen Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Touch Screen Replacement: Schritt 2, Bild 1 von 2 Kurio Xtreme Touch Screen Replacement: Schritt 2, Bild 2 von 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Touch Screen Replacement: Schritt 3, Bild 1 von 3 Kurio Xtreme Touch Screen Replacement: Schritt 3, Bild 2 von 3 Kurio Xtreme Touch Screen Replacement: Schritt 3, Bild 3 von 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Touch Screen Replacement, Touch Screen: Schritt 4, Bild 1 von 1
    • Unscrew the three 4 mm screws with a Phillips #000 screwdriver.
  5. Kurio Xtreme Touch Screen Replacement: Schritt 5, Bild 1 von 2 Kurio Xtreme Touch Screen Replacement: Schritt 5, Bild 2 von 2
    • Remove the orange data display ribbon wire above the battery by prying open the ZIF connector with the plastic opening tool.
  6. Kurio Xtreme Touch Screen Replacement: Schritt 6, Bild 1 von 2 Kurio Xtreme Touch Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove the orange data display ribbon wire to the left of the battery by prying open the ZIF connector with the plastic opening tool.
  7. Kurio Xtreme Touch Screen Replacement: Schritt 7, Bild 1 von 2 Kurio Xtreme Touch Screen Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Slide iFixit's Plastic Card tool or a credit card under the battery to remove the glue that is holding it in place.
    • Be patient and gentle. The glue is strong and may take up to 30 seconds to remove.
    • Carefully lift the battery out of the device and set it aside.
    • Be careful not to disconnect the black and red wires from the motherboard when setting the battery aside.
  8. Kurio Xtreme Touch Screen Replacement: Schritt 8, Bild 1 von 1
    • Carefully remove the speakers out of the plastic molds by lifting up the black and red wires. Set the speakers aside.
    • Be careful not to disconnect the black and red wires from the motherboard when setting the speakers aside.
  9. Kurio Xtreme Touch Screen Replacement: Schritt 9, Bild 1 von 2 Kurio Xtreme Touch Screen Replacement: Schritt 9, Bild 2 von 2
    • Remove the motherboard by lifting it out of the casing and set it aside along with the battery and speakers.
    • The motherboard will still be connected to the battery, speakers, and the gray ground wire.
  10. Kurio Xtreme Touch Screen Replacement: Schritt 10, Bild 1 von 1
    • Carefully peel the ground wire tape off of the blue front screen panel.
    • It is not necessary to peel the tape off of the back of the silver LCD screen.
  11. Kurio Xtreme Touch Screen Replacement: Schritt 11, Bild 1 von 2 Kurio Xtreme Touch Screen Replacement: Schritt 11, Bild 2 von 2
    • Pry open all 7 of the blue clamps by wedging the plastic opening tool under them and bending them backward.
    • The clamps will not "snap" open. This step requires you to actually bend the plastic back.
  12. Kurio Xtreme Touch Screen Replacement: Schritt 12, Bild 1 von 2 Kurio Xtreme Touch Screen Replacement: Schritt 12, Bild 2 von 2
    • Remove the LCD display from the blue touch screen casing by gently shaking them apart in the palm of your hand.
    • This could be stuck on, so you need heat to loosen the glue.
    • Be careful when prying the digitzer from the plastic, if you bend it too much it can break the frame!
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Mallory Myers
1.190 Reputation
7 Anleitungen geschrieben
Baylor, Team 6-10, Williams Fall 2015 Mitglied von Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Mitglieder
14 Anleitungen geschrieben
2 Kommentare
Thanks - very good guide! For the investment of an iFixit toolset and less than 10 GBP for a replacement digitizer, I was able to restore my little boy's treasure!
Patrick Niessen - Antwort
Thank you so much for the Guide!! Helped save Christmas!!! The steps were easy to follow and my kids tablets are back to new.
tdd82 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 3,379
