Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Be sure the device is turned off. Flip the phone onto its backside. Remove the back cover by using a plastic opening tool.
    • Be sure the device is turned off.
    • Flip the phone onto its backside.
    • Remove the back cover by using a plastic opening tool.
  2. Remove the eight screws with a JIS #0 screwdriver. Remove the eight screws with a JIS #0 screwdriver. Remove the eight screws with a JIS #0 screwdriver.
    • Remove the eight screws with a JIS #0 screwdriver.
  3. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  4. Once the back cover is removed, the (6) buttons along the side are going to fall out of place. Once the back cover is removed, the (6) buttons along the side are going to fall out of place. Once the back cover is removed, the (6) buttons along the side are going to fall out of place.
    • Once the back cover is removed, the (6) buttons along the side are going to fall out of place.
  5. Using the plastic opening tool from earlier, lift the battery out by wedging it along the edge. Using tweezers, unlock the ribbon cable port and lightly pull the cable upwards until it becomes unplugged. Using tweezers, unlock the ribbon cable port and lightly pull the cable upwards until it becomes unplugged.
    • Using the plastic opening tool from earlier, lift the battery out by wedging it along the edge.
    • Using tweezers, unlock the ribbon cable port and lightly pull the cable upwards until it becomes unplugged.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Dylan Ulbricht
582 Reputation
5 Anleitungen geschrieben
Sam Houston State, Team S15-G4, Blackburne Fall 2018 Mitglied von Sam Houston State, Team S15-G4, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G4
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 31
Insgesamt: 269
