Was du brauchst
Begin with the phone on its side.
Use the plastic opening tool to remove the cover. It is easier to begin near the volume button. The cover should pop off on its own.
Remove the 8 screws around the outer portion of the phone with the JIS #0 screwdriver bit.
Use the plastic opening tool to remove the backside of the phone.
Slide the plastic opening tool under the battery to pry it up and remove it.
Once the battery pops out, remove the orange tape that connects the battery to the phone.
Next, remove the 2 screws connecting the mounting bracket.
Remove mounting bracket.
