Zum Hauptinhalt wechseln
Kyocera DuraForce Pro Headphone Jack Replacement
Was du brauchst
  1. Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 1 von 3 Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 2 von 3 Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: Schritt 1, Bild 3 von 3
    • Flip the phone on its side so that the volume button is facing up.
    • Use the plastic opening tool to remove outer case of the phone.
    • Remove the 8 screws around the outer portion of the phone with a JIS #0 screwdriver.
  2. Kyocera DuraForce Pro Headphone Jack Replacement: Schritt 2, Bild 1 von 3 Kyocera DuraForce Pro Headphone Jack Replacement: Schritt 2, Bild 2 von 3 Kyocera DuraForce Pro Headphone Jack Replacement: Schritt 2, Bild 3 von 3
    • Remove the 2 screws with the same screwdriver bit.
    • Remove battery from the phone with plastic opening tool.
  3. Kyocera DuraForce Pro Headphone Jack Replacement: Schritt 3, Bild 1 von 3 Kyocera DuraForce Pro Headphone Jack Replacement: Schritt 3, Bild 2 von 3 Kyocera DuraForce Pro Headphone Jack Replacement: Schritt 3, Bild 3 von 3
    • Once the battery pops out, use tweezers to gently pull the ribbon out along with it.
    • Remove the 2 screws along the sides of the mounting bracket, then remove the bracket.
  4. Kyocera DuraForce Pro Headphone Jack Replacement: Schritt 4, Bild 1 von 3 Kyocera DuraForce Pro Headphone Jack Replacement: Schritt 4, Bild 2 von 3 Kyocera DuraForce Pro Headphone Jack Replacement: Schritt 4, Bild 3 von 3
    • Remove final ribbon cable, lift the latch up, and then slide it down. The audio jack will then slide out.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Dylan Ulbricht
735 Reputation
5 Anleitungen geschrieben
Sam Houston State, Team S15-G4, Blackburne Fall 2018 Mitglied von Sam Houston State, Team S15-G4, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 1,304
