Zum Hauptinhalt wechseln
Kyocera Echo Camera Replacement
Was du brauchst
  1. Kyocera Echo Camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient the phone so that the screen is face down.
    • Place one or both thumbs near the small arrow at the bottom of the phone and firmly push the cover up.
  2. Kyocera Echo Camera Replacement: Schritt 2, Bild 1 von 1
    • Pull up on the back cover and lift the top to separate it from the phone.
  3. Kyocera Echo Camera Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery out of the device with a thin object such as your nail or credit card.
  4. Kyocera Echo Camera Replacement, Camera: Schritt 4, Bild 1 von 1
    • Unscrew four 4.3mm Phillips #000 screws.
  5. Kyocera Echo Camera Replacement: Schritt 5, Bild 1 von 1
    • Unscrew two 4.8mm Y000 screws.
  6. Kyocera Echo Camera Replacement: Schritt 6, Bild 1 von 2 Kyocera Echo Camera Replacement: Schritt 6, Bild 2 von 2
    • Wedge a plastic opening tool under the black outer casing of the phone. Push the plastic opening tool down and outward while rotating the phone to pry the black outer casing off.
    • Do not apply too much pressure to the outer casing, as it could damage internal components.
  7. Kyocera Echo Camera Replacement: Schritt 7, Bild 1 von 2 Kyocera Echo Camera Replacement: Schritt 7, Bild 2 von 2
    • Wedge a plastic opening tool under the bottom of the circuit board and push upward to separate the circuit board from the back of the phone.
    • Be careful to not break the circuit board as it is connected to the hinge.
  8. Kyocera Echo Camera Replacement: Schritt 8, Bild 1 von 1
    • Push the camera gently out of its housing towards the side of the circuit board it is connected at to dislodge it.
  9. Kyocera Echo Camera Replacement: Schritt 9, Bild 1 von 1
    • Grasp and pull up on the 32 pin connector attached to the circuit board to remove the camera.
Abschluss
Alex Kinstedt
483 Reputation
4 Anleitungen geschrieben
IUPUI, Team S2-G6, Baechle Fall 2018 Mitglied von IUPUI, Team S2-G6, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 238
