Zum Hauptinhalt wechseln
Kyocera Echo Flash and Motherboard Replacement
Was du brauchst
  1. Kyocera Echo Flash and Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient the phone so that the screen is face down.
    • Place one or both thumbs near the small arrow at the bottom of the phone and firmly push the cover up.
  2. Kyocera Echo Flash and Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Pull up on the back cover and lift the top to separate it from the phone.
  3. Kyocera Echo Flash and Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery out of the device with a thin object such as your nail or credit card.
  4. Kyocera Echo Flash and Motherboard Replacement, Flash and Motherboard: Schritt 4, Bild 1 von 1
    • Unscrew four 4.3mm Phillips #000 screws.
  5. Kyocera Echo Flash and Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Unscrew 2 Y1000 4.8 mm screws.
  6. Kyocera Echo Flash and Motherboard Replacement: Schritt 6, Bild 1 von 2 Kyocera Echo Flash and Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Wedge a plastic opening tool under the black outer casing of the phone. Push the plastic opening tool down and outward while rotating the phone to pry the black outer casing off.
    • Do not apply too much pressure to the outer casing, as it could damage internal components.
  7. Kyocera Echo Flash and Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Wedge a plastic opening tool under the motherboard directly above the flash. Additionally, use a plastic opening tool to unhook corner labeled in a red square.
  8. Kyocera Echo Flash and Motherboard Replacement: Schritt 8, Bild 1 von 2 Kyocera Echo Flash and Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Gently pull the motherboard out of its compartment.
Abschluss
Alex Kinstedt
483 Reputation
4 Anleitungen geschrieben
IUPUI, Team S2-G6, Baechle Fall 2018 Mitglied von IUPUI, Team S2-G6, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 182
