Zum Hauptinhalt wechseln
Kyocera Echo Front Screen Replacement
Was du brauchst
  1. Kyocera Echo Front Screen Replacement, Front Screen: Schritt 1, Bild 1 von 2 Kyocera Echo Front Screen Replacement, Front Screen: Schritt 1, Bild 2 von 2
    • Orient the phone so that the screen is facing up. Place the metal spudger in the half-circle opening located near the bottom right of the Sprint logo at the top of the screen, identified with a red square.
  2. Kyocera Echo Front Screen Replacement: Schritt 2, Bild 1 von 1
    • Gently wedge the metal spudger between the top screen and the phone to separate it. Continue wedging along the outside of the screen carefully with the metal spudger until the screen is apart.
Abschluss
Alex Kinstedt
483 Reputation
4 Anleitungen geschrieben
IUPUI, Team S2-G6, Baechle Fall 2018 Mitglied von IUPUI, Team S2-G6, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 183
