Zum Hauptinhalt wechseln
Kyocera Event Battery Replacement
Was du brauchst
  1. Kyocera Event Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Kyocera Event Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Kyocera Event Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Battery Replacement: Schritt 2, Bild 1 von 1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ohio State, Team 1-1, Michaels Fall 2013 Mitglied von Ohio State, Team 1-1, Michaels Fall 2013
OSU-MICHAELS-F13S1G1
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 4,137
