Zum Hauptinhalt wechseln
Kyocera Event Camera Lens Replacement
Was du brauchst
  1. Kyocera Event Camera Lens Replacement, Camera Lens: Schritt 1, Bild 1 von 3 Kyocera Event Camera Lens Replacement, Camera Lens: Schritt 1, Bild 2 von 3 Kyocera Event Camera Lens Replacement, Camera Lens: Schritt 1, Bild 3 von 3
    • Flip phone over and remove back cover
  2. Kyocera Event Camera Lens Replacement: Schritt 2, Bild 1 von 1
    • Use the screwdriver with the Y0 bit attached to take out the seven 5mm screws that attach the back cover on the phone. Make sure to keep track of these screws, as they are pretty important.
  3. Kyocera Event Camera Lens Replacement: Schritt 3, Bild 1 von 1
    • Next, use the metal spudger to pry at the plastic clips. Be careful to not to lose the power button and volume buttons as they fall out. Remove the plug for the camera flash.
  4. Kyocera Event Camera Lens Replacement: Schritt 4, Bild 1 von 3 Kyocera Event Camera Lens Replacement: Schritt 4, Bild 2 von 3 Kyocera Event Camera Lens Replacement: Schritt 4, Bild 3 von 3
    • Use the spudger to pry the camera lens and remove it from the rear frame. Then you can replace the lens.
Abschluss
ryan
221 Reputation
1 Anleitung geschrieben
Colorado Springs, Team 1-2, May Spring 2015 Mitglied von Colorado Springs, Team 1-2, May Spring 2015
UCCS-MAY-S15S1G2
4 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 1,466
