Zum Hauptinhalt wechseln
Kyocera Hydro Life Charging Port Replacement
Was du brauchst
  1. Kyocera Hydro Life Charging Port Replacement, Charging Port: Schritt 1, Bild 1 von 2 Kyocera Hydro Life Charging Port Replacement, Charging Port: Schritt 1, Bild 2 von 2
    • Remove the back of the phone.
  2. Kyocera Hydro Life Charging Port Replacement: Schritt 2, Bild 1 von 3 Kyocera Hydro Life Charging Port Replacement: Schritt 2, Bild 2 von 3 Kyocera Hydro Life Charging Port Replacement: Schritt 2, Bild 3 von 3
    • Remove the battery by pulling up on the end and towards yourself.
  3. Kyocera Hydro Life Charging Port Replacement: Schritt 3, Bild 1 von 1
    • Use a PH0 screwdriver to remove the 6 screws which are holding the panel in the phone.
  4. Kyocera Hydro Life Charging Port Replacement: Schritt 4, Bild 1 von 3 Kyocera Hydro Life Charging Port Replacement: Schritt 4, Bild 2 von 3 Kyocera Hydro Life Charging Port Replacement: Schritt 4, Bild 3 von 3
    • Remove the frame from around the back of the phone.
    • Then remove the back panel of the phone.
    • Remove the white sticker from in the middle of the phone.
  5. Kyocera Hydro Life Charging Port Replacement: Schritt 5, Bild 1 von 3 Kyocera Hydro Life Charging Port Replacement: Schritt 5, Bild 2 von 3 Kyocera Hydro Life Charging Port Replacement: Schritt 5, Bild 3 von 3
    • Desolder the 7 pins.
    • If you have never soldered before, follow this guide.
    • This type of soldering requires very specialized and expensive equipment. Please be careful if you decide to continue following this guide.
  6. Kyocera Hydro Life Charging Port Replacement: Schritt 6, Bild 1 von 2 Kyocera Hydro Life Charging Port Replacement: Schritt 6, Bild 2 von 2
    • Desolder the positive and negative terminals.
  7. Kyocera Hydro Life Charging Port Replacement: Schritt 7, Bild 1 von 1
    • Peel back the copper plated sticker.
    • If the copper plated sticker is broken, it must be replaced. If it is not broken during disassembly, it can be reused.
  8. Kyocera Hydro Life Charging Port Replacement: Schritt 8, Bild 1 von 1
    • Remove the motherboard without breaking it by placing it to the side. It will still be attached to the phone.
  9. Kyocera Hydro Life Charging Port Replacement: Schritt 9, Bild 1 von 1
    • Using force, remove the charging port from the charging slot.
  10. Kyocera Hydro Life Charging Port Replacement: Schritt 10, Bild 1 von 1
    • Replace the charging port and ribbon.
    • If the copper-plated sticker is damaged, it will need to be replaced as well.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 983
