Einleitung
Follow this guide if you do not hear broadcast audio from your phone, such as media, speakerphone, ring tones, or other audibles. If this guide is not followed exactly, it will ultimately result in a damaged device. Ensure audio issues are not software related (programs being muted, master volume muted, other settings) before proceeding.
Was du brauchst
Use tweezers to pull away insulation from speaker, and expose positive and negative terminal points.
Plug in solder iron, allow 2-4 minutes to come to temperature.
Apply solder iron to each speaker terminal, and melt connection.
When connection is melted, use tweezers to remove defective speaker from the motherboard.
Insert new speaker into speaker slot.
Solder new positive and negative terminals.
To reassemble your device, perform steps 5 through 1 constructively.
