Einleitung
A step-by-step rear camera replacement guide for the Kyocera Hydro Life smartphone.
Was du brauchst
Flip the phone so that the screen is facing down.
Gently remove the back cover with the grip at the bottom of the phone.
Remove the six Phillips #00 screws from the back of the enclosure.
Use a plastic opening tool to gently remove the plastic piece surrounding the back of the phone enclosure.
Using a plastic prying tool, gently loosen all 4 corners of the motherboard.
Lift the motherboard away from the phone enclosure.
