Zum Hauptinhalt wechseln
Kyocera Hydro Vibe Camera Button Replacement
Was du brauchst
  1. Kyocera Hydro Vibe Camera Button Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe Camera Button Replacement: Schritt 2, Bild 1 von 3 Kyocera Hydro Vibe Camera Button Replacement: Schritt 2, Bild 2 von 3 Kyocera Hydro Vibe Camera Button Replacement: Schritt 2, Bild 3 von 3
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe Camera Button Replacement, Trim: Schritt 3, Bild 1 von 1
    • Locate the screws holding the trim which are the four side screws on each corner.
    • Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
  4. Kyocera Hydro Vibe Camera Button Replacement: Schritt 4, Bild 1 von 2 Kyocera Hydro Vibe Camera Button Replacement: Schritt 4, Bild 2 von 2
    • Locate the clasps holding the trim in place.
    • You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
  5. Kyocera Hydro Vibe Camera Button Replacement: Schritt 5, Bild 1 von 1
    • The trim is flimsy.
    • This is what the trim will look like once removed.
  6. Kyocera Hydro Vibe Camera Button Replacement, Camera Button: Schritt 6, Bild 1 von 3 Kyocera Hydro Vibe Camera Button Replacement, Camera Button: Schritt 6, Bild 2 von 3 Kyocera Hydro Vibe Camera Button Replacement, Camera Button: Schritt 6, Bild 3 von 3
    • Now that you have taken apart the trim, the camera button should be easily removable.
    • Locate the camera button. When looking at the back side (battery side), the camera button will be on the left side.
    • Take the camera button out with tweezers.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 262
