Einleitung
This guide will step you through how to replace the headphone jack on the Kyocera Hydro Vibe. This replacement is needed if the headphone jack does not produce sound when headphones are plugged into it. The repair should take about an hour. You will need to purchase a new headphone jack. You will also need a spudger and a Phillips #000 screwdriver. There are no foreseen hazards. You will want to be careful when taking apart the phone as to not damage it further.
  1. Pop the back plate off by using your hands or a spudger. Pop the back plate off by using your hands or a spudger. Pop the back plate off by using your hands or a spudger.
    • Pop the back plate off by using your hands or a spudger.
  2. Remove the trim from the phone by carefully prying it away using your hands. Remove the trim from the phone by carefully prying it away using your hands. Remove the trim from the phone by carefully prying it away using your hands.
    • Remove the trim from the phone by carefully prying it away using your hands.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove six Phillips screws (screw length of 5.35 mm and screw head diameter of 2.95mm) on the back of the device using a Phillips #000 screwdriver. Remove six Phillips screws (screw length of 5.35 mm and screw head diameter of 2.95mm) on the back of the device using a Phillips #000 screwdriver.
    • Remove six Phillips screws (screw length of 5.35 mm and screw head diameter of 2.95mm) on the back of the device using a Phillips #000 screwdriver.
  5. Remove the battery by popping it out of the phone by using your hands or the spudger to pry it up out of the case. Remove the battery by popping it out of the phone by using your hands or the spudger to pry it up out of the case. Remove the battery by popping it out of the phone by using your hands or the spudger to pry it up out of the case.
    • Remove the battery by popping it out of the phone by using your hands or the spudger to pry it up out of the case.
  6. Remove the inner plate from the phone using the spudger or your fingers. Remove the inner plate from the phone using the spudger or your fingers.
    • Remove the inner plate from the phone using the spudger or your fingers.
  7. Remove the headphone jack using the spudger to push down on the jack to dislodge it from the phone. Once the headphone jack is dislodged, you can disconnect the ribbon cable by carefully pulling it out. Once the headphone jack is dislodged, you can disconnect the ribbon cable by carefully pulling it out.
    • Remove the headphone jack using the spudger to push down on the jack to dislodge it from the phone.
    • Once the headphone jack is dislodged, you can disconnect the ribbon cable by carefully pulling it out.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Katherine Pfeiffer
154 Reputation
1 Anleitung geschrieben
IUPUI, Team S3-G6, Harley Fall 2018 Mitglied von IUPUI, Team S3-G6, Harley Fall 2018
IUPUI-HARLEY-F18S3G6
3 Mitglieder
2 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 73
