Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will walk readers through the steps toward replacing the SIM card.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Make sure that the device is turned off before beginning.
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. The large white component is the battery. Look for a small indentation under the arrow that says "LIFT." Place the plastic opening tool in the indentation and lift the battery out of the socket. Place the plastic opening tool in the indentation and lift the battery out of the socket.
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Locate the SIM card indicated by the arrows and picture.
    • Locate the SIM card indicated by the arrows and picture.
  4. Use the precision tweezer set to safely remove the SIM card. Use the precision tweezer set to safely remove the SIM card.
    • Use the precision tweezer set to safely remove the SIM card.
Abschluss
Kunal Patel
562 Reputation
3 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 430
