Zum Hauptinhalt wechseln
Kyocera Oystr Screen Replacement
Was du brauchst
  1. Kyocera Oystr Screen Replacement, Removing the battery: Schritt 1, Bild 1 von 3 Kyocera Oystr Screen Replacement, Removing the battery: Schritt 1, Bild 2 von 3 Kyocera Oystr Screen Replacement, Removing the battery: Schritt 1, Bild 3 von 3
    • Make sure the phone is turned off before disassembly.
    • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
    • Remove the battery from the casing. This is simply a precaution.
    • Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
  2. Kyocera Oystr Screen Replacement, Removing screws from screen: Schritt 2, Bild 1 von 3 Kyocera Oystr Screen Replacement, Removing screws from screen: Schritt 2, Bild 2 von 3 Kyocera Oystr Screen Replacement, Removing screws from screen: Schritt 2, Bild 3 von 3
    • Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
    • Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
  3. Kyocera Oystr Screen Replacement, Exposing internal components: Schritt 3, Bild 1 von 3 Kyocera Oystr Screen Replacement, Exposing internal components: Schritt 3, Bild 2 von 3 Kyocera Oystr Screen Replacement, Exposing internal components: Schritt 3, Bild 3 von 3
    • Lift the plastic cover of the phone screen upwards with a plastic opening tool.
    • Remove the two screws from the metal cover.
  4. Kyocera Oystr Screen Replacement, Removing metal cover: Schritt 4, Bild 1 von 1
    • Remove the metal cover by lifting up and away from the device.
  5. Kyocera Oystr Screen Replacement, Screen removal: Schritt 5, Bild 1 von 3 Kyocera Oystr Screen Replacement, Screen removal: Schritt 5, Bild 2 von 3 Kyocera Oystr Screen Replacement, Screen removal: Schritt 5, Bild 3 von 3
    • Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
    • Use your fingernail to detach the ribbon connecting the board to the screen.
    • Remove the damaged screen from the device.
  6. Kyocera Oystr Screen Replacement, Completing the repair: Schritt 6, Bild 1 von 1
    • Follow these steps in reverse order to replace Kyocera Oystr’s screen.
Abschluss
David
24 Reputation
2 Anleitungen geschrieben
UW Stout, Team 5-7, Zhou Fall 2011 Mitglied von UW Stout, Team 5-7, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G7
2 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
My screen goes blank for days, then shows. maybe for minutes of seconds. Do I need to replace the screen, or is there a control I can try to bring back the display? The phone is charged and rings. Yours is a wonderful website. Thank you.
Martha Carnahan mpc@netsync.net
Martha Carnahan - Antwort
My screen goes blank for days, then appears, but only for minutes or seconds before it goes blank again. Do I need to replace the screen, or do you know if there a command which would solve the problem? The phone is charged and rings.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 2,234
