Zum Hauptinhalt wechseln
Kyocera QCP-2035 Display Replacement
Was du brauchst
  1. Kyocera QCP-2035 Display Replacement, Remove Back Cover: Schritt 1, Bild 1 von 3 Kyocera QCP-2035 Display Replacement, Remove Back Cover: Schritt 1, Bild 2 von 3 Kyocera QCP-2035 Display Replacement, Remove Back Cover: Schritt 1, Bild 3 von 3
    • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
    • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
    • In 5 mm it will stop sliding.
  2. Kyocera QCP-2035 Display Replacement: Schritt 2, Bild 1 von 3 Kyocera QCP-2035 Display Replacement: Schritt 2, Bild 2 von 3 Kyocera QCP-2035 Display Replacement: Schritt 2, Bild 3 von 3
    • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
    • Turn the phone over slowly. The battery will fall out on its own.
  3. Kyocera QCP-2035 Display Replacement: Schritt 3, Bild 1 von 3 Kyocera QCP-2035 Display Replacement: Schritt 3, Bild 2 von 3 Kyocera QCP-2035 Display Replacement: Schritt 3, Bild 3 von 3
    • Rotate the phone so the bottom is facing you. There is a small indent on the plastic face.
    • Using the tip of your fingernail or a spudger, pry the cover away from the rest of the phone.
    • Once the cover starts to part, keep separating until the top notches detach.
  4. Kyocera QCP-2035 Display Replacement: Schritt 4, Bild 1 von 3 Kyocera QCP-2035 Display Replacement: Schritt 4, Bild 2 von 3 Kyocera QCP-2035 Display Replacement: Schritt 4, Bild 3 von 3
    • With the cover plate separated, you will see (6) T6x11mm torx screws recessed in the white plastic.
    • Remove screws.
    • The white plastic face plate lifts right off, exposing the main board.
  5. Kyocera QCP-2035 Display Replacement, Display: Schritt 5, Bild 1 von 3 Kyocera QCP-2035 Display Replacement, Display: Schritt 5, Bild 2 von 3 Kyocera QCP-2035 Display Replacement, Display: Schritt 5, Bild 3 von 3
    • Lift the display straight up, by either grabbing it on it's sides, or sliding a pair of tweezers between the screen and the main board.
    • There are four straight plastic pins on the underside corners of the screen that hold it in place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Scott Whitney
301 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 5-3, Brown Winter 2015 Mitglied von USF Tampa, Team 5-3, Brown Winter 2015
USFT-BROWN-W15S5G3
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 177
