Einleitung
If battery power is draining too quickly, or if it is unable to hold a charge altogether, it's time to replace the battery. The task is simple and straightforward, with minimal tools required. Follow this guide to replace the battery for your Kyocera Zio M6000.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Press down on the back of the phone, applying moderate pressure.
Slide the back casing down to separate it.
Remove the back casing to expose the battery.
Use a plastic spudger to lift the battery out using the battery's groove on its top left corner.
Ein weiterer Nutzer hat diese Anleitung absolviert.
