Zum Hauptinhalt wechseln
Kyocera Zio M6000 Digitizer Replacement
Was du brauchst
  1. Kyocera Zio M6000 Digitizer Replacement, Battery: Schritt 1, Bild 1 von 2 Kyocera Zio M6000 Digitizer Replacement, Battery: Schritt 1, Bild 2 von 2
    • Press down on the back of the phone, applying moderate pressure.
    • Slide the back casing down to separate it.
  2. Kyocera Zio M6000 Digitizer Replacement: Schritt 2, Bild 1 von 2 Kyocera Zio M6000 Digitizer Replacement: Schritt 2, Bild 2 von 2
    • Remove the back casing to expose the battery.
    • Use a plastic spudger to lift the battery out using the battery's groove on its top left corner.
  3. Kyocera Zio M6000 Digitizer Replacement, Motherboard: Schritt 3, Bild 1 von 2 Kyocera Zio M6000 Digitizer Replacement, Motherboard: Schritt 3, Bild 2 von 2
    • Remove the six 3.18 mm screws using a Phillips 00 screwdriver.
  4. Kyocera Zio M6000 Digitizer Replacement: Schritt 4, Bild 1 von 2 Kyocera Zio M6000 Digitizer Replacement: Schritt 4, Bild 2 von 2
    • Insert the flat end of the spudger between the front and back panels, and pry it apart by running the spudger along the side to further separate them.
    • Go all the way around, prying as you go, until the back casing completely separates from the rest of the phone.
  5. Kyocera Zio M6000 Digitizer Replacement: Schritt 5, Bild 1 von 3 Kyocera Zio M6000 Digitizer Replacement: Schritt 5, Bild 2 von 3 Kyocera Zio M6000 Digitizer Replacement: Schritt 5, Bild 3 von 3
    • Unclip the two flex cables -- a small one located on the left side on the lower half of the motherboard, and a longer one on the right side, higher up.
  6. Kyocera Zio M6000 Digitizer Replacement: Schritt 6, Bild 1 von 3 Kyocera Zio M6000 Digitizer Replacement: Schritt 6, Bild 2 von 3 Kyocera Zio M6000 Digitizer Replacement: Schritt 6, Bild 3 von 3
    • Pry out the earpiece speaker using the spudger.
    • Pry out the vibration motor using the spudger.
  7. Kyocera Zio M6000 Digitizer Replacement: Schritt 7, Bild 1 von 2 Kyocera Zio M6000 Digitizer Replacement: Schritt 7, Bild 2 von 2
    • Place the flat end of the spudger underneath the digitizer connector and pry it up to disconnect it.
  8. Kyocera Zio M6000 Digitizer Replacement: Schritt 8, Bild 1 von 3 Kyocera Zio M6000 Digitizer Replacement: Schritt 8, Bild 2 von 3 Kyocera Zio M6000 Digitizer Replacement: Schritt 8, Bild 3 von 3
    • Remove the sticker to uncover the screws underneath.
    • Remove the six 1.59 mm screws using a Phillips 00 screwdriver.
  9. Kyocera Zio M6000 Digitizer Replacement: Schritt 9, Bild 1 von 3 Kyocera Zio M6000 Digitizer Replacement: Schritt 9, Bild 2 von 3 Kyocera Zio M6000 Digitizer Replacement: Schritt 9, Bild 3 von 3
    • Lift the bottom portion of the motherboard away from the front panel.
    • Do not forcefully pull the components apart as there is another connector on the underside of the motherboard attaching it to the panel.
    • Insert the flat end of the spudger in between the panel and motherboard to unfasten the connector.
  10. Kyocera Zio M6000 Digitizer Replacement, Digitizer: Schritt 10, Bild 1 von 3 Kyocera Zio M6000 Digitizer Replacement, Digitizer: Schritt 10, Bild 2 von 3 Kyocera Zio M6000 Digitizer Replacement, Digitizer: Schritt 10, Bild 3 von 3
    • Remove the two rubber pieces from the ends of the panel.
  11. Kyocera Zio M6000 Digitizer Replacement: Schritt 11, Bild 1 von 3 Kyocera Zio M6000 Digitizer Replacement: Schritt 11, Bild 2 von 3 Kyocera Zio M6000 Digitizer Replacement: Schritt 11, Bild 3 von 3
    • Remove the red Power button and green Talk button from the bottom of the casing.
    • Remove the trackball, also at the bottom of the casing.
  12. Kyocera Zio M6000 Digitizer Replacement: Schritt 12, Bild 1 von 3 Kyocera Zio M6000 Digitizer Replacement: Schritt 12, Bild 2 von 3 Kyocera Zio M6000 Digitizer Replacement: Schritt 12, Bild 3 von 3
    • Pry the bottom edge of the bezel with the flat end of the spudger.
    • Carefully run the spudger up the sides until the digitizer is free.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Scott Nguyen
522 Reputation
3 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015 Mitglied von USF Sarasota-Manatee, Team 1-2, Stewart Fall 2015
USFSM-STEWART-F15S1G2
5 Mitglieder
17 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 341
