Einleitung
Kyvol supplied the Cybovac L20 with a 3200mAh lithium-ion rechargeable battery. This guide should be useful for sufficient battery repairs if:
- The battery will not charge.
- The battery doesn’t stay charged.
- The device doesn’t turn on.
Was du brauchst
Begin with the device laying on a flat surface with the power button facing up.
Use a Phillips #1 screwdriver to remove two 1 mm screws that secure the panel.
Remove the battery panel.
Slightly lift the battery out of the compartment.
Disconnect the battery connector.
Completely remove the battery.
